Transmission Swap - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Transmission Swap
Old 09-05-2017, 05:25 PM   #1
Martini Racing
1.8L
Car: 2000 Impreza L 2.2. Mixed reds
Fav Mod: Stock Suspension.
Default Transmission Swap
Hello friends.
I have the drivetrain from a 02 WRX, being the 5 speed trnamission, wheel hubs, brakes, axles, and drive shaft. They're going to go into a 2000L, built in December of 99.
I do own a 97 5 speed ECU and wiring harness, but I can tell these are different from the 2000 I own.
So what on the electrical side do I need to support this transmission swap?
Martini Racing is offline   Reply With Quote
Old 09-05-2017, 09:59 PM   #2
starplatnumm
Car: 00 rs silver
Fav Mod: JDM transmission swap
Rear diff????? Gear ratio diameter? I'm not sure if the 97 rear diff matches with wrx02 rear diff......
November,December,yah all through the winter, I'm alive........
starplatnumm is offline   Reply With Quote
Old 09-07-2017, 07:16 PM   #3
Martini Racing
1.8L
I have the matching Rear Diff, forgot that detail. Lets try again.
5 Speed Transmission.
Rear Diff.
Driveshaft.
4 Half shafts.
Rear Hubs.
Front Hubs.
Clutch Master Cylinder.
Pedal Set.
Clutch fluid distributor looking thingy.
97 Impreza 5 speed ECU with wiring harness.
Brakes & rotors.
Clutch.
Flywheel.
All subframe Mounts.
Manual Starter.
There we go, I even spelled Transmission correctly.
