To build or not to build - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 09-09-2019, 03:49 PM   #1
bobby17772
1.8L
Car: 1996 impreza brighton
Fav Mod: 1.8 heads 2.2 bottom end
Default To build or not to build
Hey guys, first off if this is in the wrong section please feel free to move it. But not sure the rout that I want to take.
I have a 98 L with a 2.2 that's a winter beater, but I've been wanting to do something fun with it, so I was thinking of doing a build for it (semi budget just because the body has seen better days).
I was thinking of either going high compression na with nitrous, or low compression turbo. I plan to keep the bottom end a 2.2 so I'd probably swap heads either 1.8 or 2.5 depending on which way I go.
I was going to get a junk yard engine and rebuild the bottom end and freshen up the heads and a slight port and polish job. But yeah what do you guys think would be more fun? This would just be something to drive once in a while and take to the track. This isn't something I'm expecting to run 10's in just something fun
Thanks for any advice or input
bobby17772 is offline   Reply With Quote
Old 09-09-2019, 11:05 PM   #2
SoCoNoHa
2.7L
Fav Mod: Anything custom
I had a 1.8, slapped 2.2 Turbo heads on there, and proceeded to have my mind blown by wastegate boost pressure(7-8psi). Eventually went to a 2.2 bottom end with 2.5 DOHC heads, got the boost up to about 17psi... fastest car I've ever been in by a good margin.
Turbo will probably be more work, however;
More potential
Cool sounds
Never needs refilled
Fun diy project, if somewhat involved.
Slap some EJ25D or EJ20G heads on your 2.2 block with a stock WRX turbo, and I guarantee you will love it. Just gotta decide what you'll do for tuning.
Turbo all the way! Not that a high comp NA with NOS wouldn't be cool though...
97 LGT / 92 SVX / 95 GM∆
SoCoNoHa is offline   Reply With Quote
Old 09-18-2019, 07:01 PM   #3
kay95
Car: 95 L, 96 OUTBACK
Fav Mod: p1 SUSPENSION
You could also put a 2.5 block in under the 2.2 heads with cams. That is fun to drive. It makes tons of torque.
kay95 is offline   Reply With Quote
