gd radiator in gc / fans question - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 04-15-2019, 03:45 AM   #1
jeff6666p
Car: 98 impreza rs black
Default gd radiator in gc / fans question
Will the fans from my rs bolt onto the gd wrx rad? If not can I swap my rs fans in to the gd shroud?
jeff6666p is online now   Reply With Quote
Old 04-15-2019, 07:26 AM   #2
SoCoNoHa
2.7L
Fav Mod: Anything custom
I have GD radiator in my '95, the radiator fits great but you'll need a GD top hose I think. As for the fans, the little feet will sit in the radiator tabs, but the bolt holes don't line up at all, and I think I had to trim a little off one shroud near the top radiator inlet. Zip ties have been very effective for me, but you could probably fab up some simple brackets if you want to be baller.
92 SVX / 95 GM2 / 02 GDE / 03 GDA
SoCoNoHa is offline   Reply With Quote
Old 04-18-2019, 01:49 PM   #3
IWire
Premium Vendor
IWire's Avatar
Fav Mod: Swap
Trader Rating: (23)
It's not a direct swap for the fans but you should be able to use the WRX fans although it'll be a bit tight with the radiator hose.
We make a shroud so the upper bolt spots match up - iWire GC to GD Radiator Adapter Shroud
iWire Subaru Wiring Services
949-510-8278
www.iwireservices.com
IWire is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
GD transverse links a decent alternative to ALK on GC models? RoadRunner Suspension, Brakes, Rims & Tires 25 04-21-2012 11:27 PM
Late 90's gc ej20g drivetrain into 04 gd spindles Axion20010 Transmission & Drivetrain 13 12-04-2011 06:19 PM
GD control arm bushings into GC control arms SIMER Suspension, Brakes, Rims & Tires 3 06-23-2011 02:41 AM
Vorshlag GD camber plates on my GC vs... Richard A/ Suspension, Brakes, Rims & Tires 1 09-03-2008 07:34 PM
differences in fuel delivery between GC & GD homer09 N/A Tuning 0 12-23-2005 09:28 AM
