EJ20G Throttle Body IACV Coolant Bypass - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 05-28-2011, 02:07 PM   #1
eastfreestyler
I <3 JDM
eastfreestyler's Avatar
Trader Rating: (54)
Default EJ20G Throttle Body IACV Coolant Bypass
Well, summer is here and it's hot out.
I've been reading how it's one of the best and cheapest mod on their EJ20G out there. I'm planning to do it over the weekend
Anyone else want to tell me otherwise?
Feedbacks? especially the one who lives on the cold east coast area.
Thanks
I <3 My Imprezas
eastfreestyler is offline   Reply With Quote
Old 05-28-2011, 02:59 PM   #2
69subaru360
Trader Rating: (15)
I had to do it on mine. I had to cut the fitting off the throttle body, it was where my fmic pipe needed to be. So I had no choice but to bypass it.
I've never had any problems in the winter.
69subaru360 is offline   Reply With Quote
Old 05-28-2011, 03:25 PM   #3
curtis
Car: fast wagon, toyota 4x4
Fav Mod: intermittent dash rattle
Trader Rating: (6)
is there a DIY guide? i couldnt seem to find one
curtis is offline   Reply With Quote
Old 05-28-2011, 03:31 PM   #4
JaeILV2
L On Roids.
JaeILV2's Avatar
Car: 98L 2.2
Fav Mod: Ya GF in Passenger Seat
Trader Rating: (42)
I always thought replacing the stock ej20g with coil packs off a USDM is one of the best mods for the ej20g.
Very interested in seeing this mod.
JaeILV2 is offline   Reply With Quote
Old 05-28-2011, 03:39 PM   #5
jdmflcl
2.5L RS-T
Car: 99 GM8
Fav Mod: Function is Form
Bad idea if you ever have to drive the car in cold weather.
GDnotCOOL: "Whoa! Mikey she isn't huge!"
jdmflcl is offline   Reply With Quote
Old 05-28-2011, 05:35 PM   #6
eastfreestyler
I <3 JDM
Trader Rating: (54)
That's really good to know, you're in PA so it's similar weather as me.
Do you have problem on cold start or idle
I can make diy if anything, It's similar to the one in northrusalia.
I know usdm coilpack conversion is the best to prevent future problems.
But this mod is the cheapest and can help cool down the car, esp in summer.
I'll just take it out in the winter if I come across any weird idle or cold start issues.
I <3 My Imprezas
Old 05-28-2011, 05:52 PM   #7
Jake
2.5L RS-T
Trader Rating: (21)
-20F ambient temps with an open hoodscoop at 70mph on a car with no tb coolant bypass.
You'll be just swell
Jake is offline   Reply With Quote
Old 05-29-2011, 01:44 PM   #8
69subaru360
Trader Rating: (15)
Zip zero, nada no problems at all with mine. Starts and runs completely normal in subzero weather. If you really want to blow your mind I have big fmic on mine too so even lower intake temps.
Go to a hardware store, buy a 3/8 brass hose coupler. Take the hoses off the throttle body and connect them with the coupler. Done.
I only did it because I had to, my fmic pipes didn't clear. I don't think it will make a much of a difference if any.
Old 05-29-2011, 02:12 PM   #9
eastfreestyler
I <3 JDM
Trader Rating: (54)
Wow, I just did the mod and my motor loves it. There's noticeable gain after the install on my test drive.
here's the DIY for others.
You need 3/8" doublebarb fitting and some new hose clamps if you want.
Take out your TMIC (self explanatory - no need pics for this)
There are 4 connections around throttle body and iacv (1-4 left to right)
You can see in this picture that 2&3 are connected together (you leave them alone)
Take out 1 and 4 (green arrow)
Hose 1
Hose 4
Connect them together
Install TMIC and check for coolant leak.
I <3 My Imprezas
Old 05-29-2011, 02:34 PM   #10
JaeILV2
L On Roids.
JaeILV2's Avatar
Car: 98L 2.2
Trader Rating: (42)
I think I'll give it a try.
