Fender mounted oil cooler - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 01-02-2018, 01:35 PM   #1
Hyper
Car: 99 WRB GC V9 Spec C RA recce
Trader Rating: (10)
Default Fender mounted oil cooler
since I couldn't find much info on the subject, I figured I'd post what I've done
fender was the only possible location for me (can't put it in front or on top for reasons) so after a lot of testing, cutting and pain its finally in
I am catching the air from the side bumper vent (below the turn signal) and from behind the fog light, so I had to open up the hole a bit
after A LOT of test fittings and rotations, this was the only feasible way to put the cooler in if I wanted to leave the ports pointing towards the engine (long story short, I actually regret it a bit)
I realized that without ducting, the air would go everywhere BUT the cooler, so I had to get creative
first of all I built ducting that mounts to the rear of the bumper
and then a box around the cooler that would connect with the bumper ducting
powered by vodka
Hyper is offline   Reply With Quote
Old 01-02-2018, 01:35 PM   #2
Hyper
Trader Rating: (10)
result looks like this
another HUGE challenge was to route the lines to the Mocal thermostat sandwich, which is mounted UNDER the OEM heat exchanger, I had to use 45* fittings from the sandwich to route the lines above the manifold (didn't want to run under because the lines would be the lowest point of the car, and if I hit something with them.... well you know, kaboom)
no leaks so far, no pressure drop either
when I have time, I plan to make cuts in the fender linear for the hot air to escape
powered by vodka
Old 01-02-2018, 04:57 PM   #3
scruff3333
Premo pile
scruff3333's Avatar
Fav Mod: broken motor
Trader Rating: (10)
Looks great, I think I seen where MRT use to mount a cooler in a simular position. Nice work.
scruff3333 is online now   Reply With Quote
Old 01-02-2018, 06:00 PM   #4
FryphaX
FryphaX's Avatar
Fav Mod: Registration!
Trader Rating: (4)
That's pretty bad ass. Be careful with the fender liner holes though, if you drive in snow it will end up caking everything with ice.
Old 01-03-2018, 07:34 AM   #5
George.of.the.Jungle
Baby❤Daddy
George.of.the.Jungle's Avatar
Fav Mod: BOOOOOOST!!
Trader Rating: (75)
that looks really good! i like.
Old 02-14-2018, 01:17 PM   #6
flyboynextdoor
Fav Mod: DIY Aerosim widebody!
Trader Rating: (4)
Well done
flyboynextdoor is offline   Reply With Quote
Old 05-12-2019, 04:30 AM   #7
Hyper
Trader Rating: (10)
I plan to reroute few things, and I might be selling this setup if anyone is interested in good core cooler with proper ducting
powered by vodka
Old 05-12-2019, 09:10 AM   #8
TopElement
1.8L
Car: All AWD, some turbo
Good fabrication work. Looks nice.
How effective has it been?
'18 F350 tow rig, '17 Porsche Macan S, '12 STi hatch, '99 RS rally car, '99 RSTi
TopElement is offline   Reply With Quote
