DIY: Auto To Manual Swap - Page 6 - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 12-18-2009, 05:03 PM   #51
Smoke
Interior Paint Pro
Fav Mod: Recaro seat
Trader Rating: (3)
I have a big project ahead of me now.
JDM STi engine swap
STi drivetrain swap (the entire thing)
Auto to manual swap
Smoke is offline   Reply With Quote
Old 01-09-2010, 02:16 PM   #52
wrxr4ti
wrxr4ti's Avatar
Car: 98 RSTi
Fav Mod: Turbo....
Originally Posted by Letze View Post
Smoke no, the manual starter has to come from the proper phase engine (phase I or phase II which ever it may be)
I know that this is not true. I am using a 95 L MT fwd starter on a 99 phase II rs MT transmission. worked great and saved me alot of money for the Auto to MT swap.
wrxr4ti is offline   Reply With Quote
Old 01-09-2010, 03:04 PM   #53
Letze
Car: 98 2.5RS ~ EJ257D Hybrid
Fav Mod: Ghetto Ones
Until you learn that phase 2 Motors and Transmissions Use a 6 bolt system where Phase 1 uses a 4 bolt system. so when you mix and match you get problems.
When I used a phase 2 transmission on my phase 1 Ej25D block I was forced to tap out the hole that would have lead to a bolt I didnt have, I tapped it out and bolted the starter to the transmission.
Letze is offline   Reply With Quote
Old 01-14-2010, 12:56 PM   #54
98BaRusti
Fav Mod: Extreme weight savings
Trader Rating: (30)
So the starter you use needs to math the motor not the tranny? I'm using a 95-96 legacy tranny so will I be able to use say an RS clutch kit and master and slave clutch?
Instagram: Dwightamite
98BaRusti is offline   Reply With Quote
Old 01-14-2010, 01:53 PM   #55
Letze
Sat down to check something, Starters themselves are the same. sorry about that.
The implamentation is different though, so if you have a choice match your phase transmission with your phase engine
Phase 2 engines can accept both phases without problems
Phase 1 engines require the transmission have a hole tapped and the starter's bracket needs to be bored/drilled out larger to accommodate a larger bolt.
Old 01-19-2010, 08:38 PM   #56
wrxsturbod
2.7L
Car: 2000 Subaru Impreza 2.5 WRXS
Fav Mod: WRX SWAP!!!
if i go with a rs 5MT to put behind my WRX swap, what starter should i get, RS or WRX, i beleive there is a RS AUTO starter on the car currently
wrxsturbod is offline   Reply With Quote
Old 01-19-2010, 09:18 PM   #57
Letze
current opinion, any manual trans starter should work, but for sake of longevity get a newer starter.
Old 01-19-2010, 09:28 PM   #58
wrxsturbod
2.7L
ok cool thank you i cant wait to start this like ASAP
Old 01-19-2010, 11:08 PM   #59
toyolla86
2.5L
Car: 85 toyota corolla, grey,turbo
Fav Mod: turbo anything.
Trader Rating: (4)
just got the subie a week or so ago and already halfway done with this swap. wired up the pedals today. good to know that clip on the clutch pedal is actually needed.
i better get to wiring that thing up to the ignition.
any tips. like, "dont cross the wires it'll fry your starter."
toyolla86 is offline   Reply With Quote
Old 01-20-2010, 12:38 AM   #60
lovemyscoob
2 > 1
lovemyscoob's Avatar
Fav Mod: sp00lin & hatchin
Trader Rating: (16)
I had to get a manual starter for my 04 wrx trans swap. The auto one's hole was too small.
1996 GM8 demon & 1993 GF8 bro wagon
lovemyscoob is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
