DIY: Auto To Manual Swap - Page 22 - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Old 01-21-2012, 07:50 AM   #211
69subaru360
Trader Rating: (15)
Originally Posted by makipsee View Post
i have searched for an answer but nothing has helped... i keep getting a p1722 code... on the ECU pin 81 is grounded and pin 80 is cut, the tcu is unplugged, i even went as far as unplugging the "dropping resistor".. and still after 2 key cycles it comes back up... could someone please help ??
You probably got the wrong pin. The pinouts are looking at the back of the ecu plugs where the wires go in.
69subaru360 is offline   Reply With Quote
Old 01-22-2012, 05:58 AM   #212
makipsee
Car: 98 2.5RS RBP
Fav Mod: exhaust
i know the pinouts r looking from the back of the plug, 69subaru360 already told me that and i know its the right pin b/c once the pin was grounded my idle came right down
makipsee is offline   Reply With Quote
Old 01-24-2012, 10:20 AM   #213
sk84fun21
Fav Mod: rhinolined 97L
Trader Rating: (9)
so everyone seems to do an older car to a new or wrx trans.
i have a 99 rs 4eat and i have the option of picking up either a 93 awd L or 96 awd L 5mt. aside from age/miles on either setup should i pick one over the other for ease of install? both are the 1.8 5mt and i assume from reading this they would both be the same difficulty to swap, correct? thanks for input
project overhaul
sk84fun21 is offline   Reply With Quote
Old 01-24-2012, 02:00 PM   #214
Wannabe WRX
Cluster Specialist
Wannabe WRX's Avatar
Fav Mod: Type R Limited# 95/1000
Trader Rating: (36)
It doesn't really matter which one you pick. It will be the same regardless.
The big thing, however, is that you match the correct rear differential to the trans.
If you pick up the 93 L, you'll need a 4.11 rear diff. If you go with the 96 L, you'll have to get a 3.90 rear diff.
Wannabe WRX is offline   Reply With Quote
Old 01-24-2012, 03:15 PM   #215
sk84fun21
Trader Rating: (9)
There a preferance towards either diff? I'll be snagging the entire car in either case so ill haveall parts
project overhaul
Old 01-24-2012, 03:47 PM   #216
Razor7
Fav Mod: Version 5 Swap
Trader Rating: (5)
To my knowledge - the 4.11 will offer slightly quicker acceleration with a higher cruising RPM. The 3.90 will accelerate less quickly but will have a more optimal cruising RPM.
IIRC, the 4EAT RS is 4.44, and 5MT is 4.11. OBS is 3.90.
There is also a difference in the gearing of both transmissions. The 3.90 will have a more usable first and second gear while the 4.11 is meant to keep you in the power-band through all (except 5th) gears. For cruising, DD work, or anything non-competetive, the 3.90 will be a cheaper and potentially better choice. Your RPMs at cruising speed on the freeway will be less, and will save you a couple MPGs here and there.
-TC
Razor7 is offline   Reply With Quote
Old 01-24-2012, 04:04 PM   #217
sk84fun21
Trader Rating: (9)
All of that is what i figured considering my wrx runs a 4.44. Its gonna be a DD so 3.9 prefered but the 93 is.cheaper
project overhaul
Old 02-12-2012, 09:21 PM   #218
98BaRusti
Fav Mod: Extreme weight savings
Trader Rating: (30)
So after reading through all of this I have a good understanding of the wiring that needs to be done, my only questions (forgive me if its stated elsewhere)
First, do I understand correctly that you cut the wire going to the mt/at id pin on the ecu and run the wire to a ground?
Secondly, if you splice the neutral switch wires at the under-hood plug (big gray one) so you still need to bridge the small black switch that's located on the side of the shifter?
Instagram: Dwightamite
98BaRusti is offline   Reply With Quote
Old 02-26-2012, 06:18 AM   #219
98BaRusti
Trader Rating: (30)
Finished the mechanical part, I went to fire it up and the starter doesnt even turn over? 12V are getting to the starter, here are the splices I made:
Two wires going to the little black switch at the shifter spliced into eachother
mt/at id pin at the ecu, cut the wire and ran a wire from the ecu mt/at id pin to a bolt.
neutral switch wires spliced into eachother at the grey at plug under the hood
Old 02-26-2012, 01:28 PM   #220
98BaRusti
Trader Rating: (30)
I just converted my FWD 4eat Impreza to AWD 5 speed, everything is done so I got in the car to start it, turned the key and nothing. I hooked it up to jumper cables, still nothing, starter doesnt even click.
I made the following splices:
Two black wires at black switch on AT shifter spliced to eachother
Both neutral switch wires from AT plug under the hood ran to opposite sides of the clutch switch
ground ecu pin for MT/AT id
thats it,got in the car turned the key and nothing, where/how should I test my issue? Also looking for a way to bypass the ignition so I can start my car temporarily
