FS (USA,WV): 1999 & 2000 RS Coupe Part Out - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Go Back   Subaru Impreza GC8 & RS Forum & Community: RS25.com > > >
Old 08-27-2017, 08:43 PM   #1
Gixxer
1.8L
Trader Rating: (12)
Cool 1999 & 2000 RS Coupe Part Out
Parts are from 1999 and 2000 RS coupes both 5 speeds.
Located in Fairmont WV & shipping isn't a problem just message me for a quote. If you want pictures of a certain part just ask.
*Links to albums of individual pictures of each part are located beside each group*
GC Parts
Engine & Drivetrain Pics: GC Engine & Drivetrain - Album on Imgur
Intake manifold $50
Rear subframe $40
Front subrframe $80
Rear differential carrier 'T' subframe $50
Rear differential $75
Transmission subframe $25
RWD converted 5 speed transmission (welded center diff) $400
Center differential (make above trans awd again) $200
Transmission mount $20
Gas cap $10
Fuel pump assembly with pump $20 (1 piece broken)
Fuel lines $50
Injectors $40 set
Clutch master $30
Slave cylinder $30
Steering rack $75
Throttle cable $10
Power steering pump $70
Power steering reservoir $15
Power steering reservoir bracket $5
Ignition coil $20
Coil packs $40 set
Throttle body $20
Oil fill neck and cap $15
Cam gears $10
Axle with one busted joint $25
Intake silencer $10
Coolant overflow tank $10
Suspension & Brakes Pics: GC Suspension & Brakes - Album on Imgur
Sway bars $40 each
Lateral links $20 each
Trailing arms $40 set
Endlinks $20 set
Control arms $25 each
Brake booster and master $40
ABS module $40
Front ABS sensors $15
Front brake caliper mount $5
Exterior Pics: GC Exterior Parts - Album on Imgur
Driver side headlight $100
Scoop $75
Hood vents $40 each
Doors $100
Rear bumper $100 (blue & black available)
Front bumper beam $75
Black trunk with small wing (no dents needs repainted) $50
Blue trunk with small wing (has few dents) $50
Inner fenders $10
Door windows $40 each
Door handles blue $30
Hood release cable $10
Roof trim $40 each (Shipping is really expensive due to size)
Windshield trim $25 each
Wiper cowl $40
Wiper motor & linkage $40
Sunroof $100
Driver Taillight trim $20
Quarter panel trim $10 each
Hood prop $5
Interior Pics: GC Interior Parts - Album on Imgur
Steering Wheel $20
Driver airbag $40
Dash bar $50 (2 available)
Hood release handle $5 (2 available)
ECU cover $10
Ebrake handle $20
Door kick panels $10 each
Wire covers for inside door kick panel $10 side
Fuel pump cover $5
Gas pedal $20
Blower motor $50
Dash cup holder $10
Rear view mirror $20
Interior lights $10 each
Seatbelts $40 (no driver front or rear center but have the rest)
Steering column $50
Speaker brackets $5 set (2 available)
Weatherstripping $5
Tweeter cover $10 each
Door handle trim and pocket $10 set
Visor clips OEM $10
Door panel bolt covers $5 set
Gauge cluster trim $10
Seat bolt covers $10 set of 4
Passenger A pillar $15
Rear heat vents $20 set (2 available)
Electronics Pics: GC Electronics - Album on Imgur
Knock sensor $10 (2 available)
Sunroof harness $10 (2 available)
Interior fuse box $20
Engine bay fuse box $20
Door ajar sensor $10
Horn and cruise control steering wheel switch $20
Cruise control dash switch $10
Hazard switch $10
Antenna with screws $25
Wiper switch $20
Airbag sensors $10 each
Airbag harness $25
Airbag control unit $25
Alternator to battery cable $10 (2 available)
Gixxer is offline   Reply With Quote
Old 08-27-2017, 10:04 PM   #2
JohnnyHeng
2.5L
selling mirror plus the switch? shipped 95132
JohnnyHeng is offline   Reply With Quote
Old 08-27-2017, 10:20 PM   #3
Gixxer
1.8L
Trader Rating: (12)
Ya I have those. PM sent
Old 08-28-2017, 03:50 PM   #4
G4Disco
1.8L
Parting out the RS shells? I'm looking for the maplight bracket.
G4Disco is offline   Reply With Quote
Old 08-28-2017, 08:02 PM   #5
Gixxer
1.8L
Trader Rating: (12)
Yep and weird you are the second person to ask about that bracket. I have one left for sale
Old 08-30-2017, 05:59 AM   #6
Iosuarrieta43
1.8L
Car: 2001 Subaru 2.5RS
Fav Mod: Assume I can afford mods
PM Sent
Iosuarrieta43 is offline   Reply With Quote
Old 08-30-2017, 06:03 AM   #7
equinox92
They call me Garrett
equinox92's Avatar
Fav Mod: Park Bench
Trader Rating: (53)
What's the paint code on the 00?
Tuned Detroit - Automotive Blog, check it!
equinox92 is offline   Reply With Quote
Old 08-30-2017, 07:03 AM   #8
Aczwild
2.5L
Fav Mod: RS-Zero's
Trader Rating: (9)
Need a rear subframe thats in good condition. Can you snap some pics of the condition of the subframes and PM them to me/post them in here? Depending on the shape of the lateral links and trailing arms I may take those as well.
Aczwild is offline   Reply With Quote
Old 08-30-2017, 08:14 AM   #9
Gixxer
1.8L
Trader Rating: (12)
Originally Posted by Iosuarrieta43 View Post
PM Sent
Replied
It was silver. Previous owner had it painted blue
Ya I'll take some pics today and post them on here.
Old 08-30-2017, 11:51 AM   #10
redfogo
1.8L
Any chance you have a RS badge and the RS front bumper vents?
redfogo is offline   Reply With Quote
