| | #1 (permalink) |
| 2.0L Turbo | I know someone that has a power FC on his JDM wrx swap. he wants to replace his MAF with a MAP so he can run flow more air without the MAF resrictions. can he just wire a normall 3 (power,ground,signal) wire MAP sensor into the power fc inplace of the MAF? or does he need something else becuase there are several map wires?
__________________ just wait till i get a extra ej22, a hatchi, and a welder. |
| | #2 (permalink) |
| Mobile Diagnosis Guy Car: 96 Legacy GT Fav Mod: EJ205 4EAT My: Subaru Parts Join Date: Jun 2004 Location: Philadelphia/Orlando Trader Rating: (23) Posts: 5,501
| the voltages that the ecu sees will be different from maf to map. you need to calibrate the changes. not sure if the power FC can do that or not. most likely will need to retune everything.
__________________ this is my signature. |
| | #3 (permalink) |
| 2.2L Turbo Car: 1WD Fav Mod: SubieSMART My: Subaru Parts Join Date: Apr 2006 Location: Berkeley, Cal. Trader Rating: (11) Posts: 2,775
| I bought a MAP sensor for my alcohol injection kit. How would the wiring work if you wanted to use it in place of the MAF?
__________________ SubieSMART.com: Follow the White Rabbit |
| | #4 (permalink) |
| 2.0L Turbo | I am not sure, that is what i am trying to figure out. i am going to call rallitek when sean gets back next week and he might be able to enlighten me.
| | #5 (permalink) |
| 2.5L Car: 94 WRX, 95 WRX, 08 SpecB Fav Mod: Driving a Subaru Join Date: Nov 2002 Location: Im hiding Trader Rating: (7) Posts: 295
| The PFC uses both MAF and MAP to run the car. Ive messed around with my PFC quite a bit, and i have never seen the option to turn one of them on or off with a logetsoftare or the hand held. And as far as the MAF goes, just get Z32, Q30 or Q45. the PFC already has accomidations for those. So all you would need to do is, switch it from GC MAF to the upgraded unit on the Handheld or the loget. |
| | #6 (permalink) |
| 2.0L Turbo | ^ interesting. well cant you run it without a map? since the GCs only have a maf? couldnt you just replace the maf with a map? arg.. confsing sensors
| Thread Tools | |
| Display Modes | |
