Register Mark Forums Read FAQ
Go Back   Subaru Impreza GC8 & RS Forum & Community: RS25.com > RS Club Technical > ECU & Electrical Modifications
Old 09-02-2005, 12:55 PM   #1 (permalink)
2.7L
Car: 2000, Subaru, Impreza, Blue Ri
Trader Rating: (25)
Default need help from electrical guru
turns out last night i lost all power to my windows, turn signals, Sun roof speedometer,RPM gauge, gas gauge, Water temp gauge......i did notice the the harness coming from the fire wall into engine compartment was burned due to the turbo's heat....i unwrapped it and found to wires that were not broken but missing a little wrap on it.....i rewraped them with electirical tape but still....have no power....would somebody happen to know where this all would connect to...cause i checked all fuses and none were bad.....
BTW...its a 2000 2.5rs
last of the 2.2 mohicans
rollingonall4 is offline   Reply With Quote
Old 09-06-2005, 01:29 PM   #2 (permalink)
The first ex-ex-moderator!
Car: 00 RS & GSX-R 750
The bulkhead wiring harness is basically your cars spinal cord so there are lots of wires in there. Can you identify the wire colors of the ones you burnt? You might have been lucky and just killed a ground. There's 18 wires that run through the firewall near the turbo. Check all your fuses too since the windows, sunroof, and such run through the bulkhead harness but the go through the driver's side fender so the would be burnt by the turbo.
You really need to do a better job protecting the harness, eletrical tape is not heat resistant.
Konichiwa bitches
puckaveli is offline   Reply With Quote
Old 09-08-2005, 04:44 PM   #3 (permalink)
2.0L
Car: 1999 Impreza RS Aspen White.
He fixed it already .
-Josh
LaParka is offline   Reply With Quote
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2009 The RS Club.
Privacy Policy
