| | #1 (permalink) |
| Premium Member Car: 97 Impreza L Fav Mod: Coilovers Join Date: Mar 2006 Location: Pittsburgh PA Trader Rating: (2) Posts: 971
| I have known about this for a while now but some one reminded me that others may be interested. There are 3 things that you need: 1. Compatible Laptop (Program known to work on Windows XP and Vista) 2. e-bay USB to OBD-2 Cable (LINK) Mine has the blue plug 3. OBD-2 Scan Software (LINK) Unzip and Install using setup file All you have to do is select the correct COM Port with the Configure Settings button and then connect. Then select the OBD2 Generic version. To Read DTC's: Go to the Read/Clear Faults tab Then Click DTC to read. To Erase DTC's: After Reading just click Clear DTC. Other Things you can do: Live Data Reading- -Open/Closed Loop Fuel System (Open/Closed) I think this is right -Calculated Load (%) -Engine Coolant Temp (°F & °C) -Short Term Fuel Trim (%) -Long Term Fuel Trim (%) -Intake Manifold Absolute Pressure (kPa & inHg) -Engine Speed (RPM) -Vehicle Speed (Km/h & Mph) -Ignition Advance Cylinder #1 (Degrees) -Mass Air Flow Sensor (Volts) -Absolute Throttle Position (%) -O2 Sensor 1 (Volts) -O2 Sensor 2 (Volts) Log Previous Data -Log and playback data Picture of my cable for referance: ![]()
__________________ Awesome Website Last edited by bubba2533; 02-07-2010 at 01:33 PM.. |
| | #2 (permalink) |
| 2.7L Car: 2000 2.5RS My: Subaru Parts Join Date: Mar 2005 Location: Marietta, Ga Trader Rating: (5) Posts: 433
| Yep I've got this as well. Been using it to flash on my WRX swap. |
| | #5 (permalink) |
| 3.3L Car: Impreza 2.5rs Fav Mod: CEL Join Date: Apr 2002 Location: Toms River NJ Trader Rating: (3) Posts: 573
| The link you posted had quite a few different ones. Some are $2 with $12 shipping... some are $14 with $2 shipping... and some $6 with free shipping... So the ones listed for VW work with 2000 subaru? Price beats tactix cable... whats the difference between them? Can you raise idle with the cable and software you linked? |
| | #9 (permalink) |
| Elite Moderator Car: '00RS+'04FXT Fav Mod: Supercharger Join Date: Dec 2001 Location: SA-TX (Hoser Expat) Trader Rating: (3) Posts: 5,319
| One thing to watch out for with those cables though. If it's a USB based cable, then it will not likely work on some of the older vehicles. Specifially, cars that only support the ISO9141 protocol. My 00RS is an ISO-9141 ECU. But, vehicles that support the kwp2000 protocol usually work fine. Here is why. The ISO9141 protocol uses what's called a "Slow Init" sequence to initialize the interface. This slow init requires the serial connection to drop to 5-baud for a short moment. Most USB chips don't support this slow of a BAUD rate. They ususally require software to do some trickery called "Bit Banging" to do a fake "slow init". So, it can work, but the software must be aware of the specific USB chipset in the cable. The KWP2000 protocol however, supports what's called a "Fast init" sequence. This fast init does not need a 5-baud drop in speed. Thus, the cable works well with most KWP2000 ECUs. Note: The ISO9141 and KWP2000 protocols are almost the same. The primary difference is the init sequence. The one place where a VagCom cable could/should work though, is with an SSM capable piece of software like ECUExplorer. This is because the SSM protocol doesn't need to change speeds for init. It just starts up at 4800baud, and goes to town!! I tried a VagCom cable on my 00RS, and had no luck. But, it was an older VagCom cable that was not USB. So, these newer ones might have better luck! And way cheapr than a Tactrix cable!! Shane.
__________________ No no, light speed is too slow! We need LUDICROUS SPEED! (now in Supercharged flavor) |
| | #10 (permalink) |
| Premium Member Car: '00 STM RS Coupe Fav Mod: Russian, JDM CF seatbelts My: Subaru Parts Join Date: Nov 2003 Location: CT Trader Rating: (1) Posts: 1,675
| hahahahahah................. you said vagcom.
__________________ Nice truck, sorry about the small penis. |
| Thread Tools | |
| Display Modes | |
