Register Mark Forums Read FAQ
Go Back   Subaru Impreza GC8 & RS Forum & Community: RS25.com > RS Club Technical > ECU & Electrical Modifications
Old 06-10-2009, 04:51 PM   #1 (permalink)
Car: 05 RS
Default Some mechanic hooked up a electronic device to my car... what is it?
A while back my car was having this idling problem and I just brought it by a local auto shop and they hooked up this electronic device to my car and it changed the rpm to under 1k at idle, prior to that it was much higher.
Anyways, I was wondering what is that? And I have reset my ECU a couple of times after that... and now it idles at like 700-800 rpm (which is normal).
What did he do to my car? I'm pretty sure what he did was not good for my car so since I have reset my ECU, did that destroy all the memory thing he programmed into my car?
Any information would be much appreciated.
jt0thevizzle is offline   Reply With Quote
Old 06-10-2009, 07:09 PM   #2 (permalink)
Car: 05 RS
Oh btw it was programmed inside the car, on the driver side to be specific.
Old 06-10-2009, 07:19 PM   #3 (permalink)
Car: Black 97 Impreza L 2Door
Fav Mod: Turbo!
a kinda small handheld unit with a full color screen that display engine data and such on the go?
ive used one before but i cant for the life of me remember the name of what it was called...
President_Douche is offline   Reply With Quote
Old 06-10-2009, 09:03 PM   #4 (permalink)
Ludicrous Mod
Skidd's Avatar
Car: 2000RSC
Fav Mod: Supercharger
Trader Rating: (4)
OBD2 Scanner.
And if he used it to change your idle, it was a subaru specific one.
No no, light speed is too slow! We need LUDICROUS SPEED! (now in Supercharged flavor)
Skidd is online now   Reply With Quote
Old 06-10-2009, 10:04 PM   #5 (permalink)
The Zombie Mod
NW OBS's Avatar
Fav Mod: Delta 2000 Cams
Trader Rating: (14)
Cool
meh... God bless you Skidd. Keeping the site real ~
"Every question asked, already has a thread..." ~ NW OBS
NW OBS is offline   Reply With Quote
Old 06-10-2009, 10:06 PM   #6 (permalink)
2.0L
Car: 1997 Impreza OBS
Fav Mod: Window Tint
i need one of those
-It's Just a Wagon-
monokichi is offline   Reply With Quote
Old 06-10-2009, 10:20 PM   #7 (permalink)
2.5L
Car: 01 Impreza 2.5rs Sedan
Fav Mod: UEL Header
yea he probably hooked up a diagnostic tool as skidd mentioned... if he adjusted settings it should be subaru specific. We use a similar tool at Nissan called "consult" which can do work in communication with the ecu... Probably preformed a process called "idle air volume learn" which puts the engine through a serise of condidtions to let it know how the engine should be running...
Andrew2.5 is offline   Reply With Quote
Old 06-10-2009, 11:19 PM   #8 (permalink)
Car: 05 RS
Ummm I doutb it was subaru specific because that auto shop I went to wasn't a Subaru specific one... Should I be concerned if it wasn't subaru specific? Would reseting ecu delete the programm that was inputted?
Old 06-10-2009, 11:21 PM   #9 (permalink)
Car: 05 RS
I also googled a OBd2 scanner and it did not look like that. It was much bigger than that.
Old 06-10-2009, 11:30 PM   #10 (permalink)
2.5L
Fav Mod: UEL Header
well it could be a snap on tool such as the "modis" was it a reputable shop or just some little place? i really wouldn't be worried about it unless it is running weird now or something.
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2009 The RS Club.
Privacy Policy
