| | #1 (permalink) |
| 3.3L Car: 97 GF4 Fav Mod: CEO, Correct Fitment Crew My: Subaru Parts Join Date: Dec 2007 Location: Atlanta, GA Trader Rating: (3) Posts: 584
| So I managed to pick up a set of Morettes. Here's the problem. When I turn my lights on, the driver's side low beam lights up in full, the passengers' side is very dim. When I hit the stalk to turn the high beams on, the driver's side low beam stays on, the driver's side high beam does not come on. The passengers' side low beam goes off, the passengers' side high beam comes on in full. I'm using the bulbs that came with the lights, I don't know how many miles are on them, etc. The relays and wiring looks correct from the diagrams I've seen. All the connections are good and clean. Here are the questions. Is this most likely a problem with 1. The wiring harness 2. The bulbs 3. The relays and how do I fix this? Thanks everyone in advance, every little bit helps.
__________________ |
| | #2 (permalink) |
| it's the bulbs, I've decided. I switched the two low-beam bulbs out and tried again. The driver's side doesn't come on at all, while the passengers' side came on full blast. Switching to high beams, the driver's side still doesn't come on - the high beam came on on the passengers' side, and the passengers' side low-beam stayed on. This leads me to conclude that the bulbs draw power from each other through the relays. Neat. Figured my own problem out.
| | #3 (permalink) |
| 3.3L Car: 1998, subaru, impreza L black Fav Mod: Evolution driving school My: Subaru Parts Join Date: Dec 2005 Trader Rating: (2) Posts: 638
| sounds like u might have gotten a wire backwards
__________________ The best mod for autocross is tightening the nut behind the wheel! |
| | #4 (permalink) |
| I figured it out. The bulbs are wired in series. ![]()
| Thread Tools | |
| Display Modes | |
