| | #1 (permalink) |
| 1.8L | Ok so I just picked up a 96 impreza the other day and the old owner converted it to power windows but did the wiring himself without actuall connecting the harnesses and instead by using quick disconnects on the pins on the switch. I took off the door panel to work on the speakers and stupidly unhooked the wires without looking at them. does anyone have a diagram/ pinout of the switch? Thanks, Luke |
| | #3 (permalink) |
| 2.2L Turbo Car: torque machine Fav Mod: dat launch control Join Date: Nov 2007 Location: WI Trader Rating: (12) Posts: 3,045
| hey, is it using rs door cards? or the l?
__________________ "did you read. you do live in wisconsin so that could be a trick question" |
| | #5 (permalink) |
| well if i can figure out my scanner..
| | #6 (permalink) |
| 2.2L | So you need the pinout for the RS window switch? PM me, I built myself a little diagram with both the L and RS Wire colors and pinouts.
__________________ www.cusportcar.com |
| | #7 (permalink) |
| 2.2L Turbo Car: 2x01 2.5RS, 97 gm4 Fav Mod: jack stands Join Date: Apr 2007 Location: goshen, in Trader Rating: (11) Posts: 2,095
| instead of making my own thread i'll bump this here is the issue I'm using RS window switches (2 door) and 07 sti harness. what works: drivers door: Window goes up and down power locks. only lock both doors, dont unlock unless i tap the red wire on the yellow wires. the botton that turns off wondows works. passenger side window wont roll down or up from the drivers switch. speakers work passenger door window goes up and down door lock locks and unlocks speakers work any help is apreciated ![]()
__________________ 2001 2.5RS SRP http://www.rs25.com/forums/f145/t122...ml#post1891100 |
| | #8 (permalink) |
| any one has wiring diagrams?
| Thread Tools | |
| Display Modes | |
