| | #71 (permalink) |
| Premium Member Car: RS>RSL (in progress) Fav Mod: resurrection abilities Join Date: Aug 2007 Location: danbury, CT Trader Rating: (22) Posts: 4,006
| i wonder if we can get a group buy?
__________________ Single Cylinder Mafia |
| | #72 (permalink) |
| pictar is Oolie! LOL Fav Mod: ISC Coilover and UEL Head Join Date: Jun 2008 Location: San Diego, CA Trader Rating: (2) Posts: 1,732
| I would love to have an ecu reflash... Anyone in SD wanna hook it up with a reflash? LOL
__________________ www.sandiegoscoobs.com |
| | #73 (permalink) |
| Super Moderator | Supers i wanna see that dyno already!
__________________ Light a man a fire and he is warm for a day, light a man on fire and he is warm for the rest of his life. |
| | #74 (permalink) | |
| 3.3L Car:
99 impreza rs 2.5 black Fav Mod: rod bearing delete Join Date: Jun 2005 Location: SW FL Trader Rating: (2) Posts: 807
| Quote:
The OBX exhaust from headers back dosent have any cats. It just has two resonators that are made to look like cats. Im going to post a picture of my RPM needle bouncing of the rev limiter at 6200. Also I will post a pic of my new intake Im making that will have: cone filter, MAF sensor, and torque box. | |
| | #76 (permalink) |
| 3.3L Car:
| Hey Supers, Took off the short ram and hooked the torque box back up, and I am totally amazed. Modded the box, borrowed the idea from SubySal except I didn't have enough pipe to make it a CAI, reset the ECU, test drove and the RPM's cut off at 6500. The intake got a lot quieter so I discovered an exhaust leak too. It seems like the RPM's drop a little slower but I think that might have something to do with an O2 sensor or two going bad. The car deffinatly pulls a lot harder. You should of seen the look of suprise on my face when I revved it passed 6k in the garage. Long story short I speed reflash works and torque box works. |
| | #77 (permalink) |
| All motor for now Car: Bugeye OBS Fav Mod: Big Cams Join Date: Nov 2007 Location: Pottstown, PA Trader Rating: (1) Posts: 2,641
| they dont tell you to use the stock torque box for nothing!!!! dont worry guys ill have some stories to post by wednesday hopefully when i get my ECU back form I-Speed!
__________________ Coupes are for chickens. |
| | #78 (permalink) |
| 2.0L Turbo Car:
'04 RS PBP w/ Black Tarmacs Fav Mod: Air/Oil separator Join Date: Jan 2004 Location: Colorado Springs Trader Rating: (0) Posts: 1,756
| Glad I could help KarateJoe ![]() You know I was quite surprised too at the effects of modding the airbox. It's not my idea though. I got the idea from someone who used a 3" rubber elbow and a straight piece of aluminum pipe. I just switched out to an aluminum elbow to make the install easier and lighter. Anyway yes I too noticed the intake quieted down quite a bit. It sounds more open like a full on race car. I also was surprised at the felt power gains. It was really noticeable at high rpm I thought, even more so than when I initially changed out the OE snorkel assembly to the PDM CAI pipe. Your are going from a 2" to 3" opening though. A 50% increase in airflow is no small thing. I for one believe the torque box should stay which is why I went through so much to keep it and make it work. I tend to favor the flat filters too. I think they create less turbulence. You know I've the RS filter is actually bigger than the WRX and STI filters. I'd say it could probably flow enough for a 5.0 liter V8. The reason I bring this up is because I switched back to paper filters after using a K&N for a while and finding some small particles getting though. I know the K&N's flow more, but paper actually filters better. So considering the over-sized filter and the dusty conditions where I live I went for maximum filtration.
__________________ .... time has little to do with infinity and jelly donuts. |
| | #79 (permalink) |
| Super Moderator | thatreminds me, i really need to clean my filter!
| | #80 (permalink) |
| 3.3L Car:
| Yeah maximum filtration is good. I have a MAF car so being that MAFs are so expensive I have a K&N cone, MAF, then 3'' pipe going to torque box w/ K&N filter in it. I was able to snag some heat wrap insulation that they use for commercial hood system exhaust duct from work today. Once I get some more pipe I'll make it a CAI and wrap it with that and post up some pics. Thanks again everybody for your help. This is the best site ever in my opinion. Joe |
| Thread Tools | |
| Display Modes | |
