Project Twin-Charge (turbo+supercharger) - Subaru Impreza GC8 & RS Forum & Community: RS25.com
Register Mark Forums Read FAQ
Old 02-10-2011, 02:50 PM   #1
anothernord
2.7L
Car: 1997 Legacy Outback
Fav Mod: Eaton M62!
Default Project Twin-Charge (turbo+supercharger)
***See my new, less ghetto build here:***
http://www.rs25.com/forums/f7/215008...running-5.html
Here's a quick video to give you an idea of what it sounds like: I'll get some better videos later.
1997 Subaru Outback: Twin Charged, 1st gear - YouTube
I though I'd start a new thread for this one, since it's different enough from the SC alone.
Everything is pretty much done, just tweaks here and there to make it daily-drivable.
List of stuff: (short)
Stock EJ25D (9.7:1)
Eaton M62 (from my old build)
JC Sports turbo kit w/TD04
CX FMIC
Emanage Ultimate
STi Yellows
E85/91 maps
Turbo XS RFL recirculated
Turbo XS knocklite
Exedy Stage 1 clutch
Lots of other things
Assembling everything:
Finally put together:
I'm running E85 with this setup, mostly as a safety factor until I can get it tuned up right.
The boost this setup produces is pretty insane, I've seen as high as 14 psi, even with a large boost leak. I picked up a Turbo XS knocklite to monitor knock, but I definitely won't be pushing anything until I figure out how to lower the boost.]
anothernord is offline   Reply With Quote
Old 02-10-2011, 02:51 PM   #2
Jake
2.5L RS-T
Trader Rating: (21)
what tuning system?
hats off to you, sir
Jake is offline   Reply With Quote
Old 02-10-2011, 02:52 PM   #3
anothernord
2.7L
Fav Mod: Eaton M62!
Emanage Ultimate, Innovate LC-1 wideband. I use the DIP switches on the front to switch between 91 OCT and E85 injection tables.
Old 02-10-2011, 02:53 PM   #4
LifelessViet
Enthusiast
LifelessViet's Avatar
Fav Mod: weight reduction
Trader Rating: (38)
looks like a BIG MESS!!! haha
FEELERS ARE DUMB STOP WASTING YOUR TIME
LifelessViet is offline   Reply With Quote
Old 02-10-2011, 02:53 PM   #5
Jake
2.5L RS-T
Trader Rating: (21)
didn't know emanage was that versatile.. nice work.
Old 02-10-2011, 02:54 PM   #6
seraphinwolf187
EZ GF w/Curves!
seraphinwolf187's Avatar
Fav Mod: EZ30R+6MT+WRC WIDEBODY!
Trader Rating: (18)
That's gotta eat gas like a pig! Which SC did you go with?
-Gaddis "I am not such a fool as I look," Plato to his desciples.
seraphinwolf187 is offline   Reply With Quote
Old 02-10-2011, 02:57 PM   #7
anothernord
2.7L
Fav Mod: Eaton M62!
The same M62 I used in my old supercharger setup. That thread is still around somewhere.
I get about 19-20MPG on E85 around town, and about 23-24 on 91 in town. Highway is 26-28 depending in speed.
Old 02-10-2011, 02:58 PM   #8
LifelessViet
Enthusiast
Trader Rating: (38)
where is the like button for this? :O
Old 02-10-2011, 02:59 PM   #9
01rs25
2.2L 22b
Car: '06 LGT
Fav Mod: 18g and EWG
Trader Rating: (15)
This still on a stock 2.2? Great work! Hats off to you sir!
Why have the turbo feed the supercharger and not the other way around though?
Life's too short, we're here for a good time, not a long time. -Colin McRae
01rs25 is offline   Reply With Quote
Old 02-10-2011, 03:03 PM   #10
anothernord
2.7L
Fav Mod: Eaton M62!
It's actually EJ25D, with newish short block. If you look closely, you'll see that this is actually a BG Legacy.
Reddevil, on NASIOC, was the inspiration for this type of plumbing, and after searching around and looking at other twin-charger setups, I found that this was a pretty common way to set it up. I don't fully understand the dynamics of it, but it works.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright © VerticalScope Inc.
