Register Mark Forums Read FAQ
Go Back   Subaru Impreza GC8 & RS Forum & Community: RS25.com > RS Club Technical > Turbo and Superchargers
Old 11-19-2006, 02:45 PM   #31 (permalink)
2.5L
Car: Impreza 2.5 Rsti :) 2004
i think i have the same problem...i noticed once I put the AFc NEO, my turbo flutters too.....at first when i start my car and drive it normally for 3 minutes it doesnt flutter, but once the car gets warmed up it starts to flutter..
VAUGHNB19 is offline   Reply With Quote
Old 11-19-2006, 02:47 PM   #32 (permalink)
2.5L
i never thought about my car fluttering..is it bad then if my turbo flutters?
Old 11-19-2006, 02:56 PM   #33 (permalink)
Car: 2005 subaru impreza RS
waste gate?
05 RS: Borla header, magnaflow catback, gw kit, UD pulley, tanabe springs, 20mm RSB, hankook rs2s,
2.5~rs is offline   Reply With Quote
Old 11-19-2006, 03:17 PM   #34 (permalink)
2.5L
what about the wastegate
Old 11-19-2006, 03:25 PM   #35 (permalink)
2.5L RS-T
Car: MY99 GF4 EJ225 EVO3-16G
IF the wastegate has a low spring rate, it'll flutter some too.
If you wanna know if it's WORKING or not...unplug the vacumm hose to the BOV, run it and let off the gas. IF it doesn't sound DIFFERENT then it IS the BOV you have.
All you gotta do is test, you won't know if you don't test and just assume.
It's about the Top End!!!
FuJi K is offline   Reply With Quote
Old 11-19-2006, 04:33 PM   #36 (permalink)
2.5L
ok i'll try it.. so is it bad then if it flutters then?
Old 11-20-2006, 01:45 PM   #37 (permalink)
2.7L
Car: 1993 Impreza Wagon Dreadnaught
Fav Mod: Turbo
IIRC the bov should not "flutter" but perhaps I am wrong here. When you take your foot off the gas and the throttlebody snaps shut, all the air in the boost tube/TMIC or whatever, rushes back towards the turbo, this would shock the turbo and can cause damage, that is why you have a BOV to vent that charge. So when you lift, the valve opens and all that postive pressure is vented away from the turbo. So, it should not open and close repeatedly as that air would be hitting the compressor.
What I think you are hearing is the wastegate. Unlike the BOV, the WG is not an open or closed deal, it opens and closes rather rapidly and can sound like a flutter. This is true if you have an electroic boost controller at WOT as well, you can actually hear the WG open and close as the controller tries to maintain a certain boost level. If you have an external gate, it can be rather pronounced. In our lgt, we have a 5lb spring and we are just running WG boost. at just under positive pressure, when I lift, you can hear the WG cycling. It sounds like a flutter.
I don't know if a BOV will Cycle like a WG.
hatchbuilder is offline   Reply With Quote
Old 11-20-2006, 02:11 PM   #38 (permalink)
1.8L
Car: 2000 2.5 RS-T Aspen White Coup
I had a HKS BOV running 7.8 psi,
I had the valve spring cut short. (about 2/3). so it would release at a lower PSI.
works perfectly!.
Theres a thread about it somewhere in NASIOC
GM6er is offline   Reply With Quote
Old 11-27-2006, 05:40 PM   #39 (permalink)
2.5L
i did what you said, but dont you mean if it doesnt sound different or me taking it as if it does sound the same when i take it off it would be the wg? cuz it still sounded the same, fluttering when i unpluged the vacumm hose....
anyway thanx to you a good thing, when i took off the hose and put it back i was looking more around the engine, and i noticed a leaking sound near the wg and turbo....i noticed a bolt off and missind between the wg and turbo. i think and hopeing that's why my wg is fluttering and hopefully will fix all of my problems ...tomorw i plan to bring it to the shop and they will use better bolts..
Old 11-27-2006, 05:50 PM   #40 (permalink)
2.5L
.... im doin this because the last reply by me was not updated..thanx
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright © 2009 The RS Club.
Privacy Policy
