| | #21 (permalink) | |
| 2.2L Turbo Car:
2005 RSTi Fav Mod: EJ257 :) Join Date: Jul 2006 Location: Bronx,NY/Bloomington, IN Trader Rating: (4) Posts: 2,154
| Quote:
:EDIT: Ok now that I think about even when revving in nuetral my friends car's BOV makes a normal noise and it's only making like 1 psi in neutral..so it can't be that its just the way it sounds under low PSI. So how can I stop the compressor surge?
__________________ Phi Kappa Sigma! Last edited by ACraPPyRS; 11-08-2006 at 10:24 PM.. | |
| | #23 (permalink) |
| 2.7L Car:
2000 BRP Subaru Impreza 2.5RS Fav Mod: 2002 WRX Swap Join Date: Oct 2006 Location: Orlando, FL Trader Rating: (6) Posts: 486
| looser spring or a BOV that is designed for a low boost setup. have you still not contacted whoever made your turbo kit? im sure you could get all this figured out in a matter of minutes if you call them. |
| | #24 (permalink) | |
| 2.2L Turbo Car:
| Quote:
__________________ Phi Kappa Sigma! | |
| | #27 (permalink) | |
| 2.2L Turbo Car:
| Quote:
| | #28 (permalink) |
| 2.2L Turbo | get a sound clip of it. ill bet its from running low boost. 7 psi isnt considered high boost either. what kind of times do you run in that boosted 25?
__________________ HomoeostasiS |
| | #29 (permalink) |
| 2.7L Car:
1993 Impreza Wagon Dreadnaught Fav Mod: Turbo Join Date: Mar 2005 Location: PDX Trader Rating: (1) Posts: 414
| could it just be your wastegate opening and closing? I bet it's your wastegate. They do that flutter sound as they vent exhaust gasses past the turbo. It is normal. It is a little weird if you have never heard it before. If everything is plumbed correctly with your vacuum lines in the right spots it should be fine. |
| | #30 (permalink) |
| 2.5L RS-T | On light boost, it'll flutter. Some people experience fluttler running a FMIC due to more air in the system as a whole than less air in the system of a TMIC. Ever hear those Supra's revving and the BOV chirping flutter?
__________________ It's about the Top End!!! |
| Thread Tools | |
| Display Modes | |
