Register Mark Forums Read FAQ
Go Back   Subaru Impreza GC8 & RS Forum & Community: RS25.com > RS Club Technical > Swaps/conversions
Old 06-17-2007, 02:27 PM   #31 (permalink)
Car: 1995 Turbo Civic Si & 2005 NSX
Fav Mod: ^^Side ways door handles
I pretty much answered my own questions with my thread.
99 rs is offline   Reply With Quote
Old 06-25-2007, 05:38 PM   #32 (permalink)
Car: Soon to be an RS... non-riced civic for now.
Default ...
Does this swap info also apply to the USDM STi components as well? Im contemplating doing the labor myself so I'm just curious to see if the procedure is the same.
Cheers.
If things aren't approached the right way, don't approach them at all.
alexlago is offline   Reply With Quote
Old 07-31-2007, 10:33 AM   #33 (permalink)
Regarding the front sway bar, what is the main difference between a WRX wagon piece and a Legacy Turbo one? I have a Legacy Turbo crossmember and (obviously) a WRX wagon one would be easier to find. If it is just a matter of attachment brackets, can't the crossmember be modified or new brackets made?
Also, without using a fuel pump controller, I plan on wiring in a Walbro and switching the fuel pump relay with a simple ignition power source. I am pretty sure that with an OpenECU flash I can remove the code for the fuel pump controller. Does this all seem right?
8Complex is offline   Reply With Quote
Old 08-10-2007, 12:22 PM   #34 (permalink)
Car: 2001 BRP RS
Fav Mod: Buying an AW RS
Woohoo! Glad to see this as a sticky. Thanks Siper
I Like It Sideways is offline   Reply With Quote
Old 08-26-2007, 10:52 AM   #35 (permalink)
Car: 2x01 2.5RS, 97 gm4
Fav Mod: jack stands
Trader Rating: (11)
question...if i just buy a wrecked wrx or sti could i just take everything out and put it in rs..... or there is more to it
Slava is offline   Reply With Quote
Old 08-26-2007, 11:30 AM   #36 (permalink)
Trader Rating: (90)
There is no difference between the Legacy SS sway and the WRX wagon one - they will both bolt up to a Legacy xmember. You can remove the code for the fpc if you opt not to use one, but keep in mind that will mean that your pump will prime 100% of the time that the ig relay is on.
Atlas is offline   Reply With Quote
Old 09-22-2007, 11:43 PM   #37 (permalink)
nfj79's Avatar
Car: 2000 Subaru Impreza 2.5RS, 2dr
Fav Mod: EJ207 Hybrid Swap
Trader Rating: (11)
Whats the name of the wire harness thats goes to the ECU?
Thanks!
nfj79 is offline   Reply With Quote
Old 09-26-2007, 12:23 PM   #38 (permalink)
Banned
Any differences between a USDM WRX motor and a USDM WRX STi motor as far as a swap goes?
Thanks!
noTe is offline   Reply With Quote
Old 09-27-2007, 01:32 AM   #39 (permalink)
Car: Evo X GSR, 07 Civic Si
Thanks!
+1
bump
fusionchicken is offline   Reply With Quote
Old 09-27-2007, 01:42 AM   #40 (permalink)
InsatiableAmos's Avatar
Car: Donk It.
Fav Mod: Suicide Lambo Doors.
Trader Rating: (17)
Thanks!
Yes, the STI is all drive-by-wire. This makes some things way easier, and many things way harder...and that's just the tip of the iceberg in differences.
Oh, and that iceberg gets WAY bigger once you start including the rest of the drivetrain. I promise.
Speaking of all this, can i remove airbag codes and the like with an ECU reflash?
InsatiableAmos is offline   Reply With Quote
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2009 The RS Club.
Privacy Policy
