Register Mark Forums Read FAQ
Go Back   Subaru Impreza GC8 & RS Forum & Community: RS25.com > RS Club Technical > DIY - How / To Installs
Old 06-16-2008, 08:57 AM   #31 (permalink)
2slo4u's Avatar
Car: 95L w/EJ20K, R6
Fav Mod: +170 chp
Trader Rating: (16)
Originally Posted by chlarock View Post
I'm not an expert on this but what I did to the block was, carfully shave any old gasket with a razor, scrubed it with acetone and a non abrasive pad then buffed off whatever remained with fine steel wool. This left a nice smooth surface. So far, no leaks. (I never inserted a picture so this may be screwed up)
That's good to hear. Just keep an eye on it for a while.
I've got a FEVER, and the only thing that can cure it is more WHP!!!
2slo4u is offline   Reply With Quote
Old 06-16-2008, 07:07 PM   #32 (permalink)
Car: 98 RS...built everything...NA?
Fav Mod: bass shakers....mmmmmmm
Trader Rating: (4)
I've heard the copper spray on the headgasket works great to fill in any imperfections as well. When I do mine I'm definatly gona check that stuff out.
98 2.5RS Monster, 98 Legacy wagon project:daily driver
Illnastyimpreza is offline   Reply With Quote
Old 06-16-2008, 07:28 PM   #33 (permalink)
Car: 93 Teal L; 2001 Aspen RS
Fav Mod: IHRTLAG -- License Plate
Trader Rating: (3)
They work on composite gaskets well but I've never seen a issue with a stock 3 layer metal Subaru gasket sealing. All of the new subaru gaskets are great.
I hope you don't actually believe the things you say. - Jurzeyfresh
Brydon is offline   Reply With Quote
Old 07-16-2008, 10:15 AM   #34 (permalink)
bugman1964's Avatar
Car: 01 rs coupe. BRP
Fav Mod: fender braces
Trader Rating: (10)
Speaking of gaskets does anyone know the part number for the engine gasket kit that includes all the bits for the headgasket? The dealer quoted me 250 after a discount.
bugman1964 is online now   Reply With Quote
Old 07-16-2008, 10:28 AM   #35 (permalink)
Car: 2000 subaru 2.5rs 4dr
Fav Mod: anything suspension
Trader Rating: (15)
this is a great DIY, can u also use a wire brush to clean off the old gaskets
check out my fitment blog---------- awdfitted.blogspot.com//-------
AWDALBERT is offline   Reply With Quote
Old 07-16-2008, 05:47 PM   #36 (permalink)
Trader Rating: (3)
Wire brush is probably a little harsh. I would stick to scotch bright which wont damage the surface.
Old 07-17-2008, 10:48 AM   #37 (permalink)
2.5L
Car: 2004 ForesterXT
Fav Mod: cammed OBS - RIP!
Trader Rating: (12)
I used a BRASS bristle brush all over the place, it didn't damage anything at all.
combined with a bit of engine cleaner or goof-off, it made everything really nice for the re-assembly
staticfritz is offline   Reply With Quote
Old 08-27-2008, 08:40 AM   #38 (permalink)
Car: 2006 Impreza WRX Limited
Fav Mod: catalyst inefficiency
Trader Rating: (3)
What is the difference in the head bolts?
Cones are like puppies without hearts; try to steer around them all. Go AutoX.
MattB is offline   Reply With Quote
Old 08-27-2008, 08:52 AM   #39 (permalink)
Car: 98 SE-R 01 RS
Fav Mod: Hella 500's
You need a 12 point socket and probably the biggest breaker bar you own.
How do I shot web?? LOL Dual Berettas!!
SD_Sr is offline   Reply With Quote
Old 08-27-2008, 10:52 AM   #40 (permalink)
Trader Rating: (3)
I mean whats the difference between the center and the outer ones...
I didn't need that big of a breaker bar for mine... just all my weight
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2009 The RS Club.
Privacy Policy
